826 Starting Issue
wolfman
About every third or fourth time I go to start my 826 D turn key on, lights in dash on and flash, hit starter button and nothing, not even a click. Mavbe the next two days it will just start right now, then next day no sound. When it takes that spell, hit starter button repeatedly about a dozen times and it'll start right up. Solenoid or bad connection(s) or ???
Well ya . And also check the safety start switch IF it is still hooked up. Clean the battery terminals and make sure that they are tight and use a test light on the wire that engages the solenoid and see if you have juice each and every time you push the button with the clutch down and the starter button is pushed . If you do not then back trac to the safety switch if still hooked up then back to the starter button and back to the key switch. If you have juice at the starter and nothing is happing then it is the post and disc in the solenoid . sometimes you can flip the disc over and flip the contacts and get by for awhile .
