I have a gas Farmall M I use to farm 160 acres. When I shut off the tractor I frequently get "dieseling" or "after-run". The only way I can stop it is by putting it in gear and letting out the clutch. Since this makes the tractor jump and/or move ahead, it's kinda dangerous.
I would like to install one of the IH fuel shutoff solenoids like are used on the Farmall 656 series gas tractors. And replace the current main fuel adjusting screw and packing nut. Wire it into the ignition switch system. I am told that the main jet is designed to give the proper amount of fuel, and the adjusting screw really isn't needed on these carburetors.
Advice? Opinions?
Advice? Opinions?
