Still trying to trouble-shoot my H clutch / pressure plate; depressing the pedal will not always disenage the clutch pressure plate. Gears still sometimes grind. I've adjusted everyting.
I'm trying to invent a device to tell, from me sitting in the seat, if the drive shaft is indeed stationary. Latest bright idea is a pressure gage mounted on a Lift-All pipe port, when it registers pressure, the drive shaft is rotating. No pressure, the drive shaft is stopped. Correct? I'd welcome any and all better ideas.
