424 making oil
Think I finally figured out why 424 makes oil. Thought for longest time it was blow - by but it will not ignite so probably not gas dilution. It is not water. It must be hydraulic fluid getting past the seals on the front mounted pump. This might also explain why I often have to drive tractor downhill to get pump to prime so my lift will work .Does this seem reasonable ? This has perplexed me for years .
