Farmall cub Sickle bar mower.
Greetings. On the end of the shaft with the pitman arm there appears to be a castellated nut. Is there a roll pin? I cannot seem to see it. I have wire brushed and soaked with penetrating fluid but still cannot see a pin. Any advice? Thank You.
Jerry
If you are referring to this nut, it doesn't have a pin in it but it is a left hand thread.
