Pictures of F-12 air cap please
I am missing my air cleaner cap and most of the screen (no riser), I can't find any closeup pictures that show how the cap is attached. I see several repo caps online but no mounting hardware. I had hoped there would be another F-12 at the show this weekend to check out, but none were there.
Thanks, Jeff
(quoted from post at 14:09:14 06/28/15) I am missing my air cleaner cap and most of the screen (no riser), I can't find any closeup pictures that show how the cap is attached. I see several repo caps online but no mounting hardware. I had hoped there would be another F-12 at the show this weekend to check out, but none were there.
Thanks, Jeff
Unlike the F20 and F30, the F12 is all spot welded together. The one on my 12 was smashed. It was easier to get a good used one.
OldF20 or the Cowman might be able to set you up.
Thank you!
This is all I have left, looks like I need a cap and some perforated metal to make the screen.
Is your screen welded to the top of the cap then?
I spent 8 months looking for a good used cap and never found one. Got a new cap with the "mesh" already attached to the cap from Rice Equipment. They may not have them any longer though.
Thank you, I had looked at the cap at Rice but didn't notice the cap with mesh attached.
I also see rice has a metal intake tube that goes from the hole through the radiator to the carb. Is that a factory piece? Right now I have a flexible radiator hose filling the gap between but it is not in good condition.
Thanks, Jeff
