beef88
My IH 986 lets the radio and cab blower stay on when I shut off the key. Is this a problem in the key switch?
I did some investigating and the relay is clicking when I turn the key on and clicking when I turn it off. Can it still be stuck on even though it stills clicks?
Yes the relay contacts loose their ability to make a good contact. Then arcing starts and can more or less weld the contacts together. The metallic part that is pulled against the electro magnetic coil still makes a click but due to the flexible design the contacts can remain closed or burned together.
