Pulling pucks
plowboy91879
New User
Hey guys I am trying to locate a puck to remove the sleeves from my farmall H. Other than having a shop make one is there a place to purchase them anymore or a website that sells the? I don't have a shop close by or enough hours in the day to find one. Purchasing would be nice. Any info or advice appreciated! Thanks
TOH, over on the Ford "N" Board does lots of custom machining and makes sleeve pullers for the Fords. You might try contacting him and ask if he would make what you need.
[email protected]
Check with your local auto machine shop to see if they have a puller and puck you can rent or borrow. They can also press the sleeves out and the new sleeves in. They may have the new sleeves or can get them. Have them install the new pistons on your old connecting rods too. Hal
E & K ag products in gainsville mo 417-679-3530 advertised in red power magazine that they sell sleeve pullers and pucks. give em a holler and see if they still sell them
You need to know if you have the increased bore (3 7/16 ) or original 3 3/8th as the puck is different due to the thin wall of the increased bore sleeve.
(quoted from post at 07:28:10 06/26/15) Hey guys I am trying to locate a puck to remove the sleeves from my farmall H. Other than having a shop make one is there a place to purchase them anymore or a website that sells the? I don't have a shop close by or enough hours in the day to find one. Purchasing would be nice. Any info or advice appreciated! Thanks
If you can't find one elsewhere, I would be glad to make one for you. I have a lathe and have turned several different sized pucks for myself and others to pull sleeves. krinne AT windstream DOT net is my email .
Ditto what Nebraska Kirk said. I have made a couple for myself. If you need one, let me know or get with Kirk. One of the 2 of us will assist.
