Note that the bolts that hold the blades on the spindle are left handed threads when you need to take them off to sharpen
or replace the blades. I bought my L-59 new and I when needed to take the blades off to be sharpened the first time it
was a real pain. It seems that the bolts had lock-tight on them from the factory. I had to take the deck off, turn it
over so I could use a 3/4 inch air wrench to get them off. I DID NOT reinstall any lock tight when I put them back on.
If I remember right, the bolt head takes a 15/16 wrench. Good luck with the Super A and the Woods. IMHO they make a
fine combination for mowing. My Super A needs rings real bad, it'll use a quart of oil to 5 gallons of gas and fouls
plugs if you let it idle too long. (My $0.02 worth. jal-SD)
