F 20 final drive fluid level
SDE
I am going to assume that the bottom plug is the drain plug and that the plug that it is just above it is the "FULL" level and that the plug that is in the front and below the top is the filler opening. AM I right?
I think I should check this while I have the wheels off of it.
Thank you
SDE
