Bull Pinion Shaft Bearing Cage(Help Please)
Farmall91
New User
Guys I need your help. I had to get a new cast bull pinion shaft bearing cage from a used parts dealer. After receiving the new piece I noticed that the part number stamped on it was different than the old one. The old one was 8518DB But the new part reads 8518DA. Is this a problem or are they the same thing, they appear to be the same. It's for a 1952 farmall h S#376074
The difference is probably very minor. As parts were made and modified as production moved forward, small changes within a series were noted by changes in the suffex letters. Interchangeability is pretty much assured. When parts were changed for model or serial number break, they are not going to use the same numeric part of the number. Jim
