I apologize for double posting. I posted it on the wrong forum originally.
I pulled the old girl up to the garage to clean her for painting. I noticed that she is missing two bolts that go down thru the frame rails by the clutch pedal. Will I be able to find square headed bolts locally? I think I could us two from the radiator mounts and replace them with hex, but I would like to not have to mix the square and hex headed bolts the are used next to each other. I might be the only one to notice that.
Thank you
SDE
Thank you
SDE
