Belt for 100 Sickle bar
dhermesc
To be honest I don't know if I have a 100 or an 1100 mower (fast hitch with trail wheel) - is there a difference in the belt size? I need to get one from the dealern and I know they won't have a clue (I'll be lucky if they even know what a sickle bar mower is).
The belt actually isn't in that bad of shape but the idler pully that sets tension is at the limit of its adjustment and the belt is pretty loose. Anyone know if that pully comes in a larger size?
i believe there are 2 different pulleys on the 100 mower. Mine just happens to be the same as my 1100 and I don't know how common the other size pulley is...
have you losened the u-bolt and slid it toward the end of the belt that makes it tighter? Or am I thinking of the right mower?
There are two belts listed for a 100. The first one is 558 141 R1 if you have a pulley # 456 568 R2 or 562 088 R1 if you have # pulley 456 567 R2. The first pulley it says was regular drive (900 rpm) and the second is a special drive (1000 rpm).
