Farmall A sickle bar mower belt size
old
Ok so fixed the pitman drive part for now by doing some welding. So go a bit done and the old belt that is who knows how old came off and will not stay on. Any body have an idea of the belt number and or the size and how wide it is. It measures 51 inches but would like to have a better idea. This is the sickle mower that mounts to the rear of an A and to mount it you have to remove the draw bar.
Thanks
Your mower will be a No. 16-A
My Owner's Manual shows two different drive pulley sizes:
Drive Pulley regular speed 10-7/8"diam. Belt No. M 32812
Drive Pulley fast speed 12-1/32" diam. Belt No. M 32813
Hope this helps. Sid.
Thanks I think the parts store can cross those number I just need to measure the top pulley and that should tell me which one it is
To bad those numbers do not cross over to any thing that O'Reilly's seem to be able to find.
I put a Gates B48 on it but while it works it is really to narrow and sit to deep in the pulley grove. So I am trying to find a wider one but have not heard back form O'Reilly's yet as to if they have found one
