pump shaft female coupling
I am looking for the part in the picture. It is available from IH for the low,low price of $211.00 plus shipping. As you can see in the picture there are two nicks where the oil seal rides. If anyone has an old pump torn down and would sell the coupling for a nominal fee I would appreciate it. E mail is open I think. Thanks, Ellis
Many years ago I did just a little brass on it and then did a good careful file and polish job. Still working many years later.
If you braze I would go the bronze route, file it down then finish with 240 grit or finer sandpaper or emery cloth, it would be the cheapest. The speedy sleeve works very well but will cost more costly.
Ellis--You do not need to do all of that, just get a speedy sleeve as Phil says. It will NOT spread the seal.
