madcleveland
Hi, hope you can provide some advice. I have a restored H, stored in a barn. This spring I loaded a fresh 6V battery and gas into "Hank" and he fired right up. I plowed 15 acres and when done, parked and shut him down. He hasn't started since, cranks fine, won't fire.
I've tested the coil and it is throwing current to the plugs as it should. I've checked the carb and cleaned it out. I thought the float was stuck because fuel would run out the weep hole when I cranked. Pull it all back together and nothings has changed. He still wont fire.
I'm thinking its a fuel issue in light of the postive coil test. Any ideas? Thanks.
