FARMALL F30 FRONT WHEELS
A friend has a early duck bill f30, has F&H spokes all around, front were completely shot and not repairable. Will F&H spokes from a f20 work if bearings and race are changed? If not where would be a good place to look for a set? We are located in centeral maryland. Thanks jim.
(quoted from post at 19:43:04 06/20/15) A friend has a early duck bill f30, has F&H spokes all around, front were completely shot and not repairable. Will F&H spokes from a f20 work if bearings and race are changed? If not where would be a good place to look for a set? We are located in centeral maryland. Thanks jim.
There is a difference in the retainer that holds the felt seal, I think the 20 wheels can be made to fit a 30. OldF20 knows the details maybe he'll see this and tell you
I belive Detwiler Tractor can also rerim yours to brand new condition. Their website is just contact info but here it is.
http://www.detwilertractor.com
The OD of the seals is different and as Cowman pointed out bearings are all the same.
if you use EVERYTHING front the F-20 they will change over, because the ID of the seals are the same
