I converted my H from mag to distributor. Distributor has new points, condenser, and I have a good coil. Got new 2 terminal switch and wire to go to from that to junction box on #1 terminal (fuse).
Wire from "field" on generator is hooked to field resistor. No fire, no lights, tractor just turns over and starter button seems to get hot in a hurry. One question: does it matter which wire goes to which terminal on ignition switch? And one other thing: there is a 4 position switch (LHDM) which is presently installed. Do I need to get a 3 position switch instead? Any help appreciated.
