IH 454 throttle linkage
I'm working on my dads IH 454 gas and it has a problem of some kind with the throttle linkage. No matter what I try it will not hold the throttle position, It's either wide open or idle. Ive gone through the IH parts list trying to see if something is missing but the best I can tell everything is there. I don't know what else to try! Any suggestions?
Hi Dustin,
See caseih parts item #19 spacer and jamb nut: http://partstore.caseih.com/us/parts-search.html#epc::mr63400ar682651
It is a bear to get at the jamb nut under the dash, be sure to unhook one terminal off the battery when working under the dash.
Taking the right side panel off will help some.
JimB
Thanks JimB! I think mine is a little different or its missing parts. I don't see any kind of spacer or jamb nut
<image src="http://forums.yesterdaystractors.com/photos/mvphoto22941.jpg"/>
