So last year they were running my 1066 on the blower and it blew the
front seal behind the damper pulley! Now i was not thier the day this
tractor did this! So I replaced the seal and decided to do the valves
cause they were getting a slight rattle did that started it ran it
around for 15 minutes tractor had a slight ping and a flutter never
had this flutter before! So tore the head off ended up it was bout
shot so had it all redone pulled a piston out since it was apart I was
gonna put new bearings in it and piston was scored so new rebuild kit
so finally after corn pLantana and all the fun I get this tractor put
together here fire it up for the first time the flutter is still seems
to be thier it don't seem to Rev up smooth like it should just
slightly not right! I don't k ow if I should run it a bit and see what
it does or could this be my injector pump causing this? Cause the rest
of the engine is new! Doesn't even hardly roll over and it's running!
But just don't seem normal like it was or should be!
