Sonny in Mn
I am trying to help a friend of mine with his H. It has been converted to 12 volts with a solenoid & push button start. It also has a magneto which has been converted to a distributor with an external coil. The negative (output) wire from the coil is connected to the side of the mag/dist where I believe the ground/shut off wire used to be. The problem is that it wouldn't start until the starter button was released or the tractor was pulled. It had a 12 volt coil at this time. I put on a 6 volt coil & a resistor & a 12 volt bypass button for starting. It will start & run fine on 12 volts but dies as soon as the bypass button is released. The output side of the resistor reads 6 volts on my voltmeter but apparently that is not enough to make the tractor run. My electrical knowledge is limited & I'm probably over my head already but I'm looking for suggestions & any wisdom on magnetos converted to distributors. Thanks in advance. Sonny
