Bryce Frazier
Just went out and fired the H up, with it idling, and the clutch out, I pulled the control rod as far as it would go, and nothing happened. Engine did bog down or anything. Then tried it with the belt pulley on (which shouldn't matter right) and it still didn't do anything.
Mom was freaked out that I was even outside, so, that is all I can do for today...
Maybe tomorrow I pop the cover off the bottom and see what is what?!
Oh, yes there was a thick ish purple fluid in it. I tried removing the cap, but it pulled everything out, the tube, seal, washer, and a spring that was on the cap, so, I need to fix that...
Any ideas? First thing would be check out the drive coupler huh? When I got the tractor it didn't even have a control rod on it, so I guessed that the hydraulics were bad, useless, or un-needed...
Bryce
Bryce
