230 240 bullet light rubber grommet
BBinOk
Where can I buy the rubber grommet that goes in the back of the bullet lights that flat 2 wire wiring goes through? All steiners has is a connector that only takes 1 wire,assuming it is for hot wire only. Thanks for any help!
I'm making a couple of assumptions on what you are asking about but I think you are asking about the original style headlights on the Farmall 230 or 240 tractors. I went through this when I restored my Farmall 240 tractor in trying to find the original style connectors and couldn't locate a source anywhere. First of all, two suppliers were used for the headlights on my Farmall 240 - Guide and Dietz. Mine were produced by Guide so that is what I had to work with and don't know what the configuration of those made by Dietz might be. I obtained my wire harness from Porch Electric which contained two sets of identical headlight wires with each having two wires to each headlight. I found some correctly sized black rubber grommets from an aerospace hardware supplier which fit the hole just find which had a small center hole for the wire to enter the back of the lamp housing. The part no. of the grommets I used was MS 35489-10 which fit the hole in the back of my Guide headlight housings just fine. Hope this helps and my email is open if you want more information concerning this issue or how to determine which manufacturer produced your headlight housing, etc., Hal.
The trick I think is the part number, and if you have that, eBay or Google or Bink or whatever, will give you the seller's name. I found the part number for the amp box grommets on H's / M's, and found a couple of suppliers.
