200 hydralics callin janicholson
dewy
you posted some numbers off of ih parts diagram 18,19 20 safty valve .when i look them up ,isee them as block cover ,,gasket didnt see no. 20.....i thougt yall were lookin at hydralic block no.224..im missing something please help....what no. are these and how to use them.....mr56592ar706760bi1263167-3..........thanks dewy
On this diagram there are two holes of interest. both are in the midline of the body. One is above the other They are circled with a squiggly black circle. The springs and valves that go in the holes are also circled. The safety and pressure regulator valves are different for different years and part numbers of system. I cannot tell you which one you have. they must all be free to move and springs in place to hold them where they belong. I would suggest finding a local individual that has either auto trans or IH , or hydraulic experience. Wishing you luck. Jim
thanks so much i understand my mix up ...iwas lookin at the 200 diagram...i believe this is the super c diagram...i have taken one of these apart ,along with these 200's....sorry to jim becker also...48 is the part number,i can not get out.the other 200 came out with magnet..this one is stuck....thanks again......dewy
