460 RC Steering Wobble
What is most likely cause? What is involved to "fix"? kelly p.s. it has power steering. pss I've cheated with H's before by putting higher pressure in one front tire and lowering the pressure in the other. This wobble is really a pretty bad one. Thanks, kelly
There is a set screw that holds the worm inside the rack.
It was loose on my 560 and a tightening was all that was required.
P.S. I did stake the set screw after tightening.
It is kind of a pain to dig the rack out of the front bolster to get to this set screw however.......
(quoted from post at 19:30:30 05/26/15) There is a set screw that holds the worm inside the rack.
Looks kinda like this
