Farmall C oil leak
Russ from MN
Location
Bemidji MN
On our C I have noticed some oil dripping out near the left brake, but it seems a little ahead of the brake. I assume it's probably the seal around the shaft behind the drum. I am a retired mechanic so I don't anticipate any problems, but any tips?
Loosen the drain plug and see if water has gotten into the gearbox. the oil level raises and causes leaks...
