Pull with 560 from Saturday video
Like Andrew said, keep the nose down and the drawbar up and you will really have something. I liked to looks of the tires and it had plenty of power.
I agree on needing weight on front now it's 10040 as you see it so I can add a bit more and still make the 10500 class that last pull you see in
this video is in 1st gear but I pulled all others in 2nd check out my other videos on there
(quoted from post at 17:11:15 05/27/15)...
BTDT ;)
You wouldn't even need more weight. If you could hang those wheel weights closer to the front it would help. Then again, more moveable weight/weights are always good*.
This is how I roll.
'Merica!
*Not always perfect. I took the PTO and hydraulics off my SMTA and I wish I had them. The other thing is their weight was in an almost ideal location and now I need to throw more weights to make up for them.
