Farmall C Carb
I have a zenith carburetor on my Farmall C. It seems that the butterfly where the shaft connects from the governor is slipping when I disconnect the shaft the butterfly seems to rotate freely on the shaft coming out of the carb. How do I fix. this problem Any help would be appreciated.
the butterfly shaft, should not come out of the carb. if it does, then the tractor would not run, in this condition. the butterfly should prevent this.
can you post a picture ?
