IH 504 Transmission Cover Removal
rjc1985
New User
I have an IH 504 with a broken shift fork and I am in the process of tearing it apart. I am wondering if I can remove the transmission cover and the 3 point hydraulic assembly at the same time or do I need to take the hydraulic assembly off first? Also, is there any tubes or standpipes that are attached to the cover that I need to watch for? I know the shift forks have to clear the top of the transmission but the parts illustrations on Case's website aren't very detailed. I hate going into something blind and ignorant so any insight is much appreciated.
Since no one commented on my question I thought I would finish this thread for someone else down the road. I pulled both the hydraulic unit and top cover with no problem. The worst part of it was getting the weight leveled out on the cherry picker.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto21491.jpg"/>
Hey RJC, thanks for the post and picture. I have a 504 with what I believe is the same problem. I have pulled all the bolts on the cover but I cannot seem to get it to move. I have looked carefully and I believe I have all the bolts out. I started to pull the hydraulic cover off hoping to find a reason why i can't get it off. Then I saw your post and that I should be able to take it off as a complete unit... Is there a trick to removing the cover? Any comments would be appreciated.
Thanks
