Ellis Kinney
I now have the extra belly pump apart. I have taken 2 pictures. In the first picture I am holding the lever off of the small ball. In the second picture I am pointing to the ball with a welding rod. Question, the ball is flat where the lever hits it. Is this an indication of wear or should it be flat. I can see machine marks on the ball so I think it is ok. The inside of the pump was extremely clean and had a light coating of grease on everything, but no oil in it. I know someone had been in it before, because I found a #3 finish nail for a cotter pin. Does anyone know of a supplier for the gasket? When I put it back together how do I get the pump lever from outside the pump into the (socket?) inside the housing? More questions later. Thanks, Ellis
