450 hydraulics
BudKaiser
I noticed that I have a hydraulic leak bt the right side of battery box.It seems to be coming from hydraulic block that runs to my fast lift cylinder. Is there o rings inside this block, it is leaking where it is seperated and runs the two hoses to the cylinder. Can I just un bolt the two bolts a take it apart and reseal ? Where can I get the parts to re seal it?
There are 2 O-rings available at your Case-IH dealer. Before re-assembling the 2 blocks, re-thread the bolts & nuts that hold everything together. A bit of anti-seize will help in the future.
Thanks Wayne. Can this be done with out taking lines off?I looked on the case Ih web site and I do not see the one that looks like mine. Mine has two steel lines in the front and two hoses coming from the rear off these two blocks going to my fast hitch cylinder.
