farmall conversion distributor?
axe55
I just trader for a farmall conversion vertical distributor Delco #111141(to replace the mag on my case sc fits great) I replaced the points,rotor & condenser. I what to replace the cap Is there a part number that I can use at local farm store, napa, etc? I cant seem to fing one one the internet thanks in advance
(sorry picture needs rotated distributor is to be vertical)
I had a 1940 Farmall M with one of those on it and I got a tune-up kit with a cap from
Steiner. This site has them also. Just look for a Delco distributor.
NAPA take the # in,they will supply a new one.Better still,take the old one with you as a sample.I've bought ALL my Farmall
ignition parts and carb kits,etc. from NAPA for years.
I called napa & gave them the distributor number. guy said it was obsolete.. ill try online..
Look at the kits for the minnieapolis moline tractors, they use the delco distributor. My minnie big mo 500 has the same distributor as my 42 m
with the delco distributor..
As other post said take the old one along then tell the counterman who told you obsolete get me one you got to be smarter that the parts men sometime.
Are you missing a #? 1111411, (last #).
If so DR-405, post from Paul F, 'Delco-Remy Distributor
part numbers-help'.I googled 111141, nothing,
1111411 lots.
When I type 111141 delco distributor. Comes up delco conversion distributor, l'll try the napa part number thanks everyone..
Like the other poster said, think you are missing the last number. Delco cap number 811735 or the NAPA number I posted is supposed to be the same.
