I recently bought a Hydro 70 from an estate sale. It is missing the metal lines and hoses that carry hydraulic oil to and from the hydro unit and the hydraulic cooler in front of the radiator. It has a short jumper hose across the two metal fittings under the fuel tank on the belly of the tractor. Could anyone post a picture of what this set of lines/hoses looks like and how they are routed to the cooler up front. The hanger brackets are also missing. Where do they bolt on? Also, is there a bracket on the rear that holds the toplink when not in use? A picture of that would be helpfull also. Thanks for any help you can give me.
