I'm helping a buddy with his 460, and I need help. The 2 point dropped and oil came out from under the seat. We removed the steel line that had a hole and had repaired. 2 point still will not go up. He has never used the 2 point, but has a loader on the tractor which works yet. There is linkage that goes from the hyd control under the steering wheel, down the left side with several pivots and runs back to the lift cylinder.
Is this a Lock for transport?? Could this keep the oil from flowing through the cylinder??
Is there something else that I'm not seeing?
Thanks.
Thanks.
