tbish
PTO spinning even in off position what could cause this. I just had tractor split to fix hi lo range don't no if I bumped something off thanks
Hi, PTO ON/OFF lever just pushes a collar connecting the PTO drive shaft to the PTO output shaft.
The PTO engagement lever mechanism has a pin that fits into a groove in the collar, the pin breaks and the PTO ON/OFF lever is no longer functional.
JimB
