FARMALL SUPER A PTO
I can't seem to get my PTO to work. Is there a trick to engaging
the lever? Should I be able to turn the shaft by hand when not engaged or engine not running?
What are the issues I'm facing?
Thanks
You need to remove the pto probably because the lever hat slides the shaft has the little end worn off as it rides in a grouve on that shaft and cant move the shaft. Closer inspection can then be made as to why is worn off.
yes, the pto shaft can be turned by hand, lever not engaged and motor not running.
with the motor off, turn the shaft by hand and try to engage the pto lever.
if you cannot. remove the unit. you may need someone to advise you
possibly coupler UP FRONT broken? then have to split tractor to work on it? is that a strong possibility...farmer neighbor mentioned...
