56 Fan 400
Hello again. I started up the tractor and ran it a bit a couple weeks ago. Was working on moving stuff around and it stopped. No worries there as I knew I was short on gas. I left it there for about a week or so as it was kinda cold anyway. Well, I got some gas and started her up without a hitch. Did some scraping as I am rebuilding my driveway. I dont like the way it is. So here is my problem besides forgetting to wear a hat in the sun for 2 hours or so, My fuel line from the bowl to the ??manifold was fine. The radiator side of the manifold leaked after I shut her off for a while. I noticed it when I went back out to look at her. The radiator side has 2 flat head screws that bolt to the manifold and feed the front cylinder. Is the leak common? Should I try to change the gasket? I turned the fuel flow off at the bowl with the petcock. I just opened it up and noticed no leak but I expect it will do so after I start working it and stop for the day. I remember someone else here having that issue but forget what the result was. Thanks.
Den
Den
