I have a 666 with a hydraulic problem, I'm not really sure what's going on. Behind the battery, there is a large hydraulic hose that connects to 2 pipes, about 7/8in - 1in diameter. It runs vertically from the top of the transmission up toward the steering wheel. I imagine it feeds oil to the steering wheel and components up there. Under normal driving conditions, it works fine. However, the problem I have is that when you actuate the hydraulic remote (to operate an implement), this hose blows off the pipe and shoots gallons of oil everywhere. I've tried several different hose clamps, stronger hoses, etc, and nothing holds it together. Any help?
