belly pump reservoir problems
al71
Calling Trulyred: Thanks very much for the reply about my 46H hyd problems. What did I do when I tried to use the old belly pump for a reservoir? Is it because the reservoir is lower than the pump? I am a retired GM electrician with apparently not enough practical hyd experience. I am listening, please tell me more.. Just because I can plumb it in doesen't mean it will work. Thanks again Al71.
I'm using Hytran case oil. My problem is the oil gets all full of bubbles and expands and runs out of the oil fill pipe.
