I recently picked up a pretty clean and excellent running 340 Utility gasser with a Farmhand loader- and a #24 CAT front dozer winch unit from a D6 mounted on the back.. Seems it had a bale spike and the guy didn't have any idea what it was for, so he whacked it off and mounted the dozer winch. Anyway, the one we had when I was a kid was a great loader tractor with a Wagner loader and the forward-reverse shuttle shifter, and power steering. This one however is manual steering, and is ridiculously hard to steer. Not bad jacked up, not sloppy and no tight spots, wheels track well etc. but doesn't want to turn on the ground. One thing isn't helping for sure, it seems someone completely filled the steering box with MP grease- possibly trying to cure a leak, although it is pretty clean with no sign of major leakage. Thinking I need to get that grease flushed out of there somehow and see if it is better with oil in it. Need to look it and the manual over to find a drain and maybe (lightly and slowly) pressure feed fluid in there to drive the grease out. Suggestions?
