farmall A parts on super A
I have a chance to buy a Farmall A with all implements. it has a mechanjcal lift. Can I use this engine in a Super A/ what driveline parts DON'T
fit? I want to use every thing but the squeal.
The engine will fit, BUT there is no place on the A block to mount the Super A hydraulic pump.
DRATS,afraid of that. it has a pump running off the PTO but that would be like using a 8n Ford!!!!!!!!!! Guess the pump could be moved to the front like a loader tractor. Super A's are too cheap to tolerate this. I'll use the tires and implements and be happy.
Take the engine parts and put them in the SA BUT the implements from the A will not WORK ON THE SA because the As are hand lift and the SA is hy lift. EX the rockshaft from the A will not fit on the SA. What implements for the A do you have?
Disc,2 row planter, single bottom plow,4' bush hog,scraper box,bedder,and a mountain of mid-mount stuff. THIS TRACTOR WAS CONVERTED to 3pt. Still crank start and magneto.
