Farmall M miss under load
bhshot
Over the winter I rebuilt the engine on my 52 M. I took it out over the weekend to do some plowing. At an idle she runs very smooth. I started plowing and it ran ok. Once I hit a few tougher spots in the soil and started to work the engine harder it developed a miss. once I got into better ground it smoothed out. Dose anyone have any suggestions? Thanks!
sounds like the coil, but could be a bad plug . would presume you have new electrical in it if the engine is overhauled.
When you get it set right, the inside of the exhaust pipe,{muffler] will be be cream colored. Black is a little to rich.
