84 hydro power steering unit leaking, help on seal placement
rjfcsa
New User
My 84 hydro was leaking pretty good at the steering orbit motor, or hand pump under the steering wheel. It should be the same unit as a 684 784 884 etc. It is a
DANFOSS STEERING UNIT
Type, OSP B80 OR
NR. 150-1025
I ordered a seal kit for the Case/IH dealer, ouch $132.00
I have a copy of a service manual, I got the unit out and carefully took it apart, I hope I have it all still timed right. But what I am having trouble with is
the inner seals on the upper end. The old ones and pictures in the service manual I have are different than what came with the kit. The old ones are a kind of
two pice that fit together. The new kit has a three pieces with it. I am not sure the order of how they go in. I will try to attach some pictures here. There is
a tan ring with a lip I would say kind of plastic material, a green ring with a metal grip ring in it, and a regular o-ring.
Any help or advise would be appreciated.
Thanks,
Russel Foster
To kind of clarify some of my thoughts. The two old seal fit together and fit in a grove on the underside of the top end of the unit. The three new pieces when set together look like they might be to tall to fit properly. The o-ring appears to be to large to fit in the grove. the green or blue colored piece will fit in the grove and seams to fill it up. The tan piece will fit within the channel or grove side of the blue piece with the wire.
Thanks again in advance.
Russel
