The easy way if it does not leak, is to remove the drive shaft and controls and plumb the return into the top (fill stand pipe) with a Y type "T" that directs flow downward. the suction connects to the drain in the bottom with a T to allow draining.
A improvement on that that gains a quart or so is to remove the pump assembly from the reservoir and fabricate block off plates to hold fluid. Jim
