super c touch control rock shaft arm
bbaro
I recently got a super c, everything seemed ok with the hydraulics and touch control until, I hooked up the two bottom fast hitch plow, the trouble I have is the touch control rockshaft arm on the right side when on the tractor never stops moving, I can set it to where I want it then it moves back and forth a few inches. I tried searching the archives but didn't have a lot of luck. thanks
dont know if supposed to do that or nott...makes you wonder why it has stop indicators for the levers...mine moves around also.....just reboilt one new rubbers,but have not installed....hope it stops that........dewy
you do have a problem. it should hold. have you cleaned the filter? checked oil level? is the hydraulic unit staying full?
http://www.cleancomputes.com/Cub/Blue%20Ribbon%20Service%20Manuals/GSS-1024%20Touch%20Control/GSS-1024%20Touch%20Control.htm
maybe this will help
Does the control lever have some resistance to it?, Has a friction disc in the lever under that tin round cover, has 2 lock nuts on the right side of that lever, takes two 5/8 wrenches to adjust I think. Tighten them up a little or maybe the disc is worn out.
gab, touch control and rockshafts worked normally until the plow was hooked up, once the arm sensed resistance is when it started to act up. both touch control levers seem ok, they are not loose
