Well finally got the 674's diesel engine rebuilt over the winter. The severe blow by was due to ring and sleeve problems. After a little break in got it out to do some work this weekend. Along with the rebuild I had the injector pump rebuilt and injectors checked with new tips. Also installed new fuel filters. After about 1.5 of bush hogging it lost power and shut down like out of fuel. Checked the tank, had fuel. Could see fuel in the filters (in glass bottoms). Loosened the drain valves under the filters. Left one only dripped and right ran a very small amount of fuel. Opened the top bleed screw and no fuel at all. Tried blowing in the tank to create pressure. It would crank, but almost immediately shut off. Still no fuel out the bleed screw. I didn't have any replacement filters on a Sunday, so pulled it to the shed. It's about 50 miles from where I live so it will have to wait till this weekend. Very frustrating, must have close to a complete blockage. Advice appreciated. Thanks
