BN Wheel weight bolts dash pod bolts
Hey guys, Im trying to tie up some loose ends on my BN. I would like to put the rear wheel weights on. Both rear rims are the pressed steel ones. What size do I need? Carriage bolts?
Also I found a "dash pod" or whatever you would call it that houses the amp gauge and light switch, but I need to two long bolts that bolt it together. Where can I find them? Arent they supposed to be long flat head screws?
Thanks for the help guys!
Find the instrument box 'bolts' at your local hardware store. #6 x 3".Regular hexhead bolt will be fine for the wts. 3/4" diameter,not sure about the length.Your hardware store can supply those too.
Dear Mr."" Jake"" I own a BN 1946 Late model. The piece you are refuring to is called the control panel. The blots are #10 or 12 stove bolts about 3 to 4 inches long with a round or pan head and either square nuts or hex nuts to fit { for better results of the nuts staying tight use self locking}. These can be bought at any reputable hardware or bolt supply house.
By the way what shape is your control panel.
The reason for asking I have one that came out on the IHC plant and was never used / both "box" and cover and would gladly part with it >> NO RUST JUST primer paint.<< If interested write me.
Wm.
