kennebunksawmill
Just took the loader off my 1952 Farmall SC. I took the whole assembly off / complete loader, controls & reservoir. I installed the correct size pipe plug fittings to block off the holes on the tractor (one on the right side where the lines are and one on the left side/ where you would add more fluid). The reervoir under the gas tank is full with fresh fluid. HERE IS THE PROBLEM....now, when I start it, the hydraulic lines get HOT very quickly....so hot it burnt the oil & paint off the lines under the governor. What can I do to fix this??? Thanks! Josh in Maine.
