Farmall 300 Brake Discs
scott6143
I was wondering if anyone knows the thickness of the new brake discs, last time I had mine apart the discs look ok but I have the brakes adjusted as far as I can, and its just not enough. Just would like to know if new discs will help, or do I need to replace the expensive parts.
Are they glazed you can rough them up with a disc sander then turn them 180 so they spin opposite from removal probably will work like new again.
New discs measure one half inch and 7/16 is as much wear as you can get unless you machine the drum.
Thank you, that's exactly what I needed. The discs I have are right at 7/16 now, looks like new ones will help.
