SC fasthitch 2 bottom plow
There are more than one type. Could be a C20 or 211 and I am sure there are more but those are the 2 I am aware of.
The one most commonly seen fast hitch moldboard plow with the Super C is the C20 which has an easily identifiable feature on the top in the large coil spring between the two main beams running front to back, Hal.
thats the one im talking about, i know a gentelman who has one for sale ive been looking at
Most likely it will have Plow Chief bottom parts which are very difficult to find at a realistic price due to the rarity of them. In order to convert the plow to the more readily Super Chief wear parts you will need to replace everything from the shank on the main beams with new frogs and their related parts. I am presently going through this on a No. 209 fast hitch plow for my Farmall 240 and finding it is a costly process even with the bottom parts quite a bit more plentiful. You can distinguish plow chief bottoms easily as they generally have a separate point which is not part of the share which cuts the dirt. My email is open if you need more information about what all is required to change bottoms from PC to Super Chief along with some possible contacts for the needed components, Hal.
Unless someone has converted something a 211 plow will not fit on a Super C with factory fast hitch. The Super C has small prongs and the 211 is a large prong plow.
